Shirestone wrote:Ok. Looks like 2 x 2 frame it is with thicker for the tongue. Thanks.
We did 2 x 2 square tube for the main frame but used pretty lightweight 14 guage.
The biggest part of the strength comes from the closed box shape, and next most important is size of box. The wall thickness is important, but only least important.
If you want to skimp on something to save weight or cost, skimp on wall thickness. Much thinner than 14 ga (0.075 inch, or a bit more than 1/16 inch) and it's harder to weld.
14 ga seems plenty strong for us.
For the tongue (A frame) we used 2 x 3 inch tube, same 14 ga. Orient the bigger 3 inch side vertical for most strength in vertical bending, that's what a tongue needs.
