Can anyone point me toward some good designs for DIY side doors? I plan to build my own and rather than reinvent the wheel I figured someone has come up with a proven design!
Thanks in advance.
working on it wrote: from another thread I used compression-type automotive doorseals, that I had leftover from restoring my old '69 Chevy C-10 pickup (I wish I still had it) in the late '90's. The seals are mounted on the 1/4" inner doorjambs of the oak bracing surrounding the solid 3/4" plywood doors (totally sealed with "the mix", and multiple coats of poly and paint), and the bottomside has an exterior doorsweep hanging down as a drip-edge, protecting the aluminum threshold there (no rubber seal there, just a wood/aluminum interface).
* Another thing about using those leftover seals from my truck restoration: they were really too thick to let the doors compress them and still remain flush with the sides, so I used scissors and cut about 1/4" width strips from the bulbs, nearest to the inner doorjamb, so they would still have plenty of rubber there, and fully compress. I nearly bought different ones, but the molded corners of the "factory-style" '67-72 Chevy C-10 door seals fit so nicely into the corners, that a little work on them was worth the effort.
aggie79 wrote:I echo what Tony said. Building your own is 1) expensive, 2) a lot of work, and time-consuming. The upside is that you get the design you want. The downsides are that self-made doors can be 3) hard to fit, 4) can be prone to warping if not constructed correctly, and can be 5) hard to seal/weatherproof.
Things like type of gasket, ...
