by featherliteCT1 » Sun Feb 07, 2021 6:04 pm
I do not know about your jack but will share what I know about grease and trailer tongue jacks.
Many greases are not compatible. If you do not know the kind of grease that is already installed, it is recommended that you clean out all the old grease before installing new grease, then stick with that kind of new grease.
If it were me, I would try to clean out the old grease and then install new water resistant, lithium based, wheel bearing grease.
As an aside, even though I have EZ Lube Dexter axles, rather than just pumping new grease into the zerk fitting, I remove the wheels, then remove all the old grease and install new grease. I was taught that procedure by our anal equipment manager who is a Purdue grad engineer (for what that is worth).
My Bulldog brand trailer tongue jack manual says:
“For side-wind models, … Apply a small amount of automotive grease to the internal gearing by removing the jack cover, or if equipped, use a needle nose applicator or standard grease gun on the lubrication point found on the side of the jack near the crank. Rotate the jack handle to distribute the grease evenly. A lightweight oil must be applied to the handle unit at both sides of the tube for side-wind models. If equipped, the axle bolt and nut assembly of the caster wheel must also be lubricated with the same light weight oil.
For top-wind models, apply a lightweight oil to the screw stem.”
