What kind of undercoat on plywood
Postby saican » Wed Jul 20, 2022 4:46 pm
Hello All,
Please advice me what king of undercoat paint should i use on my trailer decking to make it waterproof, last longer i am using plywood.
Thanks
saican
Re: What kind of undercoat on plywood
Postby JasenC » Wed Jul 20, 2022 6:22 pm
People use a number of things, Fiberglass is best but people also use roof coating, bed liner and even a good exterior paint.
I'm using pressure treated so no need for any coating. It's a little more money and heavier but probably nearly balances out on weight once you apply fiberglass or a roof coating to CDX.
I'll be done when I'm finished, if that's not fast enough, take a number.
Build Thread https://www.tnttt.com/viewtopic.php?f=50&t=74269
JasenC
Images: 122
Postby S. Heisley » Wed Jul 20, 2022 7:41 pm
There was an old trailer builder on here by the name of Gage, RIP. He swore by going to the auto parts store and buying black undercoat spray. He would then put a couple thick coats of that on the underside, not missing any spots.
Gage said he never had a problem using that. ...Just a thought.
Postby tony.latham » Wed Jul 20, 2022 10:12 pm
Nothing seals plywood like epoxy. It soaks in and plasticizes the surface.
Postby noseoil » Thu Jul 21, 2022 8:23 am
I used 2 coats of floor urethane, let it dry well, then did 2 coats of white roof coating on the bottom surface. One nice benefit, makes crawling around underneath to look at stuff easier & brighter with the white surface. A dark color is fine, but the white roof coat holds up very well & protects against water, small gravel & can be rinsed off at the car wash. Epoxy is really great as Tony said, but the lower tech still works well enough.
137905
noseoil
Images: 669
Postby saican » Thu Jul 21, 2022 8:45 am
Thanks all you guys giving me directions i bought zinsser primer sealer which is very thick paint i will apply one coat of this paint then i will apply kleen flow tumbler paintable rubberized undercoating, what do you guys think please post.
saican
Postby tony.latham » Thu Jul 21, 2022 11:04 am
saican wrote:Thanks all you guys giving me directions i bought zinsser primer sealer which is very thick paint i will apply one coat of this paint then i will apply kleen flow tumbler paintable rubberized undercoating, what do you guys think please post.
Just make sure the rubber goo is compatible with the primer. I suspect the Zinsser is made for a latex top coat?
I'm big on something that soaks into the wood surface, not a surface coating product. :thinking:
Postby saican » Thu Jul 21, 2022 1:36 pm
Thanks,I am using two part epoxy as you advised.
saican
Postby halfdome, Danny » Thu Jul 21, 2022 5:15 pm
I cover the top and bottom of the floor with plastic laminate, what most call Formica.
I spray 2 coats of contact cement on the wood and plam for a very water tight seal.
Never had a problem with it.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby JasenC » Thu Jul 21, 2022 7:43 pm
halfdome, Danny wrote:I cover the top and bottom of the floor with plastic laminate, what most call Formica.
:D Danny
I still call it Formica which is probably why young people look at me weird and then say, oh you mean plastic laminate :lol:
JasenC
Images: 122
Postby schnottus » Thu Jul 21, 2022 9:14 pm
saican wrote:Thanks,I am using two part epoxy as you advised.
Smart choice. Not strictly necessary, but I also spray any exposed epoxy with some cheap rustoleum enamel paint or undercoat since uv will cause the epoxy to break down over time.
schnottus
Images: 32
