Window Wedgie Widget (things you didn't know you needed)
Postby mnswamp » Tue Nov 01, 2022 7:30 pm
I wrapped up the major part of my teardrop build in August, and haven't written much because we've been _using it_!!! I've learned so much from this forum, and hopefully will continue to share in the coming months. I did want to pass on a small item that I've created to solve what was a chilling problem for me, and to make it available to others. I'm pretty sure the idea isn't original, but I hadn't seen it done like this before, so I'll claim my 15 milliseconds of fame right here and now!
Anyway, here's the Window Wedgie Widget https://swampwerks-teardrop.blogspot.com/2022/11/the-window-wedgie-widget.html
If you'd like one or two of your own, please drop me a note!
Geek by profession, coach by avocation, builder by need, sports hack by obsession.
I found my new calling - ¨Organizational chaos monkey¨
mnswamp
Images: 16
Re: Window Wedgie Widget (things you didn't know you needed)
Postby DJ Davis » Wed Nov 02, 2022 7:51 am
mn,
Nice concept. I like the way the layers fit into the window track. I do the same for my windows, but I use a 2" piece of lathe. Before I got "fancy," I used a stick. We're very "high-tech" here in Texas. :roll:
DJ
They say "What doesn't kill you makes you stronger." I've noted that if it doesn't kill you, it waits patiently for another opportunity.
DJ Davis
Postby Tom&Shelly » Fri Nov 04, 2022 2:38 pm
Good idea!
Here's a version made from scrap Baltic Birch, so the price of manufacture these days would be prohibitive!
https://www.tnttt.com/viewtopic.php?f=2&t=72491&start=810#p1289642
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2025
Postby Sparksalot » Fri Nov 04, 2022 5:30 pm
I’m not seeing what this gadget does?
Sparksalot
Images: 682
Postby Tom&Shelly » Sat Nov 05, 2022 5:56 am
Sparksalot wrote:I’m not seeing what this gadget does?
It allows a window to be cracked open a few inches. Something between fully open and fully closed.
Tom&Shelly
Images: 2025
Postby Sparksalot » Sat Nov 05, 2022 5:25 pm
Oh, slide UP windows. Got it. My brain is thinking of Rose and crank out windows.
Sparksalot
Images: 682
