Wander Tears DIY plans?
Postby Deesk06 » Mon Feb 27, 2023 8:07 pm
Anyone have any experience with the wander tears DIY plans? I am not 100% sure if they are good etc. but I also don't know of any other thorough plans.
I love the way their Vaga teardrop looks, and with the weight I can easily tow it.
If anyone has any other suggestions that would be great as well.
Thanks!
Deesk06
Re: Wander Tears DIY plans?
Postby MickinOz » Mon Feb 27, 2023 10:57 pm
It's a pity it is not the Renegade plans that caught your eye.
Then you could probably just use the Generic Benroy Plans.
http://www.mikenchell.com/images/GenericBenroyPlans.pdf
MickinOz
Postby Tom&Shelly » Tue Feb 28, 2023 12:01 am
Deesk06 wrote:Anyone have any experience with the wander tears DIY plans? I am not 100% sure if they are good etc. but I also don't know of any other thorough plans.
Thanks!
You might want to check this book out. Tony has plans in there, and he's on this forum to answer questions. Several folks on here have built his teardrop so you can look in the building section and see if it's what you like
https://www.amazon.com/Building-Teardrop-Trailer-Crafting-Heirloom/dp/B083XVH9XQ/ref=sr_1_1?keywords=Tony+Latham&qid=1677560365&sr=8-1
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
Postby Ottsville » Tue Feb 28, 2023 8:39 am
[quote="Tom&Shelly"]
Tom[/quote}
I came to suggest the same thing! Tony also has the cut files available if you have a CNC nearby
Ottsville
Postby tony.latham » Tue Feb 28, 2023 10:20 am
Tony also has the cut files available if you have a CNC nearby...
They are a free download. They produce a 10' long teardrop on an 8' (full sheet) CNC.
https://www.tonylatham.net/teardrop-cnc-files.html
Postby Deesk06 » Tue Feb 28, 2023 10:38 am
Wow, that is awesome! Can I ask what the dry load weight is (with custom trailer)? I am assuming the trailer plans are in your book as well.
Thanks!!
Dan
Deesk06
