...or Baking soda to help with the issue.
DJ Davis wrote:RJ,
I have to give you a big "nope" on that. When you're dealing with 100% humidity in a rainy situation like that, the only thing you can do is seal up, minimize the wet outside air coming in (yeah, you gotta have SOME air exchange!), and kick on a de-humidifier. Hope that two-cents worth helps.
Pmullen503 wrote:I think you'll have to insulate the steel frame better. You can try something like 1/4" fanfold foam over the framing on the inside. You just need to keep that surface above the dew point.
You could try double sided tape to test this, maybe on just a portion so you can compare.
tony.latham wrote:...or Baking soda to help with the issue.
What does that do? I haven't finished my first cup this morning and I'm scratching a hole in my head.
RJ Howell wrote:I bought a siliconized roof coating today that is supposed to seal and reflect UV. I'm still debating between XPS foam or Rockwool insulation.. My preference is towards the XPS due to once adhered in adds a structural value.
Headliner is still up in the air..
Pmullen503 wrote:RJ Howell wrote:I bought a siliconized roof coating today that is supposed to seal and reflect UV. I'm still debating between XPS foam or Rockwool insulation.. My preference is towards the XPS due to once adhered in adds a structural value.
I just assumed you wouldn't want to cover your composite exterior but if the condensation is on the ceiling only then that's a possibility.
Wood strips attached over the steel framing might give enough insulation to prevent excessive condensation. That could look OK and be less work than a full headliner.
I take it you have never used it in your Frig or Freezer..
tony.latham wrote:I take it you have never used it in your Frig or Freezer..
I always thought that baking soda in a fridge was to pull any unwanted odors.
Users browsing this forum: twisted lines and 3 guests
