Opinions wanted on my fender design
Postby angib » Fri Mar 17, 2006 12:37 pm
Ira wrote:I looked at where 7" would be, and that looked good. But I also measured the existing fender, and it's 7 1/4" off the wall.
You could go to 7 1/2" without a worry - because they're longer and higher, these swoopy fenders can be wider without looking silly.
Ira wrote:Also, since my axle is mounted below the springs, it doesn't appear that I'm going to have to notch the inside sides.
The notches I expected were just to go around the bracket that holds the springs and joins the two halves. On photos I've seen, this sticks out beyond the rest of the frame, so if the fender isn't cut, it won't lie flush against the body side.
Andrew
angib
5000 Club
5000 Club
Images: 231
Users browsing this forum: Bing [Bot] and 10 guests
