Just ordered....My HF trailer.
Postby Eric Adams » Tue Aug 31, 2004 11:08 pm
Larwyn wrote:One thing I did do was replace those "snap off" bolts that came with the trailer with grade 8 bolts, nuts and washers.
I thought I'd bolt it together, weld it, then take the bolts out after welding it everywhere a bolt was. I'd use the bolt holes to attach the bottom floor plywood to the trailer.
Come to think of it I never have asked, how to you secure the floor to the chassis? Through how many layers does the bolt go through? :?:
Eric Adams
Postby mikeschn » Wed Sep 01, 2004 3:49 am
The bolt goes thru the plywood, thru the subfloor, and thru the top layer of steel.
So you might need a 3" bolt, or if that's too long, you can cut it to the correct length!
MIke...
Images: 479
Postby Arne » Wed Sep 01, 2004 6:31 am
Widening the h/f was a chore (it took about 7 hours). Each piece had to be cut, carefully measured, and accurately welded. The thing is, it only has to be done once, the trailer will be used for years. And it will now take a queen-sized mattress.
The axle was a tight fit into the square tubing, so it was 'self-alligning'.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Eric Adams » Wed Sep 01, 2004 7:29 am
arnereil wrote:The axle was a tight fit into the square tubing, so it was 'self-alligning'.
What size square tubing did you use and how much wider did ya make it?
I appreciate the pointes. :)
Eric Adams
Postby Larwyn » Wed Sep 01, 2004 11:59 am
I kept the bolts in case a weld lets loose and welded in case a bolt lets loose, kind of the "belt and suspenders" insurance..... :D
I cut relief holes in the bottom of the floor to clear the frame bolts and will be drilling new holes for 3/8 x 3 inch carrage bolts to bolt the floor to the frame (floor is 2.25" thick).
Your system would work as well, I had considered it myself.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Arne » Wed Sep 01, 2004 1:32 pm
The square tubing was in my brother's 'stock pile'. Don't know what size.
I'm sure a piece of angle, say 2.5 x 2.5 x 1/4 would work, as the major load is on the spring. This was overkill, but that is what he wanted to do.
I added 14.5 inches to the width.
Added another pic to my album of trailer in garage, ready to go.
Arne
Mr. Subject Line
Images: 96
Postby mikeschn » Wed Sep 01, 2004 1:40 pm
Looks like you did a wonderful job on your trailer Arne.
And you've got so many choices of what you can build on top of that!!!
Images: 479
Postby Eric Adams » Wed Sep 01, 2004 9:52 pm
Just got a e-mail from HF, my trailer is on back order!!! No expected date for it to be back in stock!! Anyone have another source? I am real impatient... :)
Eric Adams
Postby mikeschn » Thu Sep 02, 2004 1:52 am
That's the 1175# that's on backorder, right. So buy the 1800# trailer. Besides, if you look at my last poll, the 1800# trailer seems to be prefered over the 1175# one.
:wink:
Mike....
Images: 479
Postby Eric Adams » Thu Sep 02, 2004 6:13 am
mikeschn wrote:That's the 1175# that's on backorder, right. So buy the 1800# trailer. Besides, if you look at my last poll, the 1800# trailer seems to be prefered over the 1175# one.
:wink:
Mike....
Thats my reasoning also IF I can get the 1800# one at the $299 price I heard another board member say they got it at. Problem is that you need a item# that is connected with that sale price. :)
Eric Adams
Postby mikeschn » Thu Sep 02, 2004 6:38 am
I believe you can call Harbor Freight and tell them you heard the 1800# trailer was on sale, and you don't have an item #. They'll give you the sale price.
Images: 479
Postby Eric Adams » Fri Sep 03, 2004 8:55 pm
mikeschn wrote:I believe you can call Harbor Freight and tell them you heard the 1800# trailer was on sale, and you don't have an item #. They'll give you the sale price.
Tried, no dice. I did go ahead and get the 1800# trailer. :) Cost $350. I had a $5 off and free shipping coupon. Every lil bit helps. :)
Eric Adams
Postby Eric Adams » Sun Sep 05, 2004 10:54 pm
mikeschn wrote:P.S. If you want to know what that would look like when you are done... check out this album...
http://photos.yahoo.com/dovetail28643
Mike, who's ablum is this? He a member here?
Eric Adams
Postby Eric Adams » Sun Sep 05, 2004 11:02 pm
mikeschn wrote:The bolt goes thru the plywood, thru the subfloor, and thru the top layer of steel.
MIke...
Whats the order of washers, lock washers, bolt head, nut, etc? I also have red lock-tite if you think it might come in handy? :)
Got a LARGE container of Locktite 403 (1lb) from a bud for $5. Dying to use it also. :)
Eric Adams
Postby mikeschn » Mon Sep 06, 2004 5:04 am
I would put a washer under the bolt head, and another washer under the nylock nut.
You could probably use the locktite on a regular nut instead of using the nylock nut.
Images: 479
