by angib » Tue Sep 14, 2004 6:40 am
It's the usual story on this car - in Europe the similar car has a much higher tow rating, 2650-2850lb for most versions with a 165lb nose weight limit. Based on the European car's typical kerb weight of 2750lb, the recommended 85% limit for towing a full-size caravan (British word for travel trailer) would be 2340lb.
Now the European and US Focuses (Foci?) are not exactly the same car and the European driver is probably expected to display a great deal more care when towing (and also have a much less aggressive lawyer?), but all the same...
This is NOT advice, merely comment.
Andrew
