okay to answer a few questions:
1. Yes-the hatch opening is square. The top forward edge of hatch frame is equal distance from the floor across the opening.
2. I am as perpendicular/vertical/ level/square with galley walls, floor, etc. as humanly possible.
3. There is a 1/4" gap from wall to side ribs. I just do not have spacers shoved in the gap. But its there.
4. The top frame rail is equal distance from bulkhead face across entire width of opening.
5. All six ribs, from left to right were clamped together and belt sanded to same shape across the skin contact surface of ribs. When clamped together the skin mount surface is as smooth and flat as can be across all six ribs.
When I try to make a 3rd rib to match the 2 side ribs, the top side fits fine. The birds mouth fits the top rail. The new 3rd rib stays in plane from the top of the hatch to the high point of the hatch curve. As I go further down the hatch curve with the straight edge, once I get near the hatch curve high point the new 3rd rib starts to move away from the straight edge and open up a gap. The gap gets worse as I follow the curve to the bottom. See below:
- Top of new 3rd rib in plane with both side ribs per straight edge.
- DSCF3805a.jpg (257.02 KiB) Viewed 2337 times
- Straight edge gap at new 3rd rib at bottom of hatch curve near lower seal rail
- DSCF3806a.jpg (131.87 KiB) Viewed 2337 times
The two side ribs go PAST the lower seal rail and screw into the side or end grain of the rail. The four new center ribs will need to mount on the FACE surface of the lower seal rail. They will mount to the rail by being screwed to the face of the rail from the back side of the rail.
The pictures below again best shows how, where, and why,I am cutting the 3rd rib. In theory if I cut the new 3rd rib along the pencil line where the pencil is pointing, that should allow the end of the new 3rd rib to sit right on the FACE of the lower seal rail in photo. The rib you see in this photo is the existing side rib. The side rib goes past the rail as shown and screws into the side of the rail not the face.
When I cut the new 3rd rib where it should in theory rest on the face of lower rail it comes up short. As shown at top of this post. Yet it fits fine up top. New 3rd rib in plane as I go down the hatch curve. Till about the curve high point. Then it begins to gap away from the straight edge the further down the curve I go.
- Pencil points to where I am cutting bottom for 3rd rib
- DSCF3809a.jpg (111.88 KiB) Viewed 2337 times
I think I've spent more time trying to explain the issue than solve it..
