Pmullen503 wrote:2" foam covered in canvas, sealed with ordinary house paint. Skip the wood altogether. Light and well insulated.
tony.latham wrote:I suggest you invest in a copy of the Teardrop Builder's Shop Manual. It goes into great detail on how to build the cabin using sandwiched construction.
http://www.campingclassics.com/shopman05.html
Once you've got your general construction figured out, you can decide how to finish it off.
jimbo69ny wrote:tony.latham wrote:I suggest you invest in a copy of the Teardrop Builder's Shop Manual. It goes into great detail on how to build the cabin using sandwiched construction.
Interesting. I didnt know anyone had written a book on this. Kinda steep at $50. Is it worth it? Have you read it?
Thanks!
Tom&Shelly wrote:jimbo69ny wrote:tony.latham wrote:I suggest you invest in a copy of the Teardrop Builder's Shop Manual. It goes into great detail on how to build the cabin using sandwiched construction.
Thanks!
Absolutely worth it! Consider the cost of your materials, and the time you'll invest in your build. $50 isn't really that much in the scheme of things. (Also, consider how much time Steve Fredrick put into writing it, and you may agree it is a reasonable price for him to ask.)
It has certainly saved me more than $50 in material by avoiding mistakes and failed experiments.
Thanks!
jimbo69ny wrote:Interesting. I am leaning towards using foam board and wrapping it with fiberglass. The book doesnt cover that? What about aero? Does it cover that?
KTM_Guy wrote:I'll second or third or whatever the manual with a few notes.
For me it was worth it just for the info on how to build the hatch. The info on building the doors was good but I bought doors. It's hard to justify building when you add up the cost of window, latches, hinges, etc. Plus the time to build them. I have a few hours total dealing with doors and done.
I'll say the manual needs an update. If you are going to build a woodie it's a must have. There is no info on skinning with aluminum, fiberglas, PMF. And nothing on building with foam other than using for insulation. The other info on AC and DC power, plumbing, cabinets, is the minimum to get you by if you know some what you are doing.
Todd
tony.latham wrote:jimbo69ny wrote:Interesting. I am leaning towards using foam board and wrapping it with fiberglass. The book doesnt cover that? What about aero? Does it cover that?
Nope, nope and nope.
T
