MatTech wrote:For what it's worth I've been in contact with Liquid Rubber up here in Canada about their products for use in my trailer build and they have been extremely helpful so far. Their customer service has been top notch and we have emailed back and forth over a dozen times. They are sending me dried samples of their products made specifically for me but I haven't received them yet so I can't comment on them.
If I were you I would find out what the product you have on your trailer is made of and ask them if they have something that would bond to it. They make some incredible claims of both elasticity and durability, I'm specifically looking at their polyurethane deck coating. Its uv stable and comes in colours.
Doesn't cost anything to ask questions and they would probably send you a sample too if you want. The product I'm looking at is $300 Cdn for 5 gallons and they have geotextile membrane to embed into the coating for extra strength.
If you're not in a hurry I should have my samples in a few days and will post a report in my "alternate adhesives for PMF" thread over on the foamies page.
Sent from my SM-G930W8 using Tapatalk
That's a very clean looking install! I'm guessing you park the trailer with a slight slope to the rear to shed water in that direction?Woodbutcher wrote:In the picture below you can see two ways of doing seams. I overlapped the sheets about 1.25 inches. The screws are stainless self tapping, and pre drilled in the overlap sheet. Where the diamond plate is attached I used an insert molding without the side leg on it. It gets screwed on and the screws get covered by the black filler strip, (sold in a roll) and both work well. Start at the rear of the trailer on the sides if you need a seam and work forward. That way the overlap faces the rear and you don't drive rain into the seam. I used a Latex Elastomeric caulk under the overlap. That never completely dries and will move with the expanding metal.
lacofdfireman wrote:Some great ideas and replies. Thank you. My concern is this edge right under my front window. Do I cut the sheet metal or aluminum at this edge or try and bend it there. I know the window will help hold the aluminum or sheet metal in place also just concerned about this angle. Not sure how to approach it. Originally it is sheeted with 2 separate pieces of plywood then the edge was filled with bondo and sanded. But not sure if I should try and bend a single piece around that edge or cut it into two pieces like was done originally.
This is the corner and edge I’m talking about.
Also along the top should I bend the top piece from the front angle and overlap over the roof piece 6-8” from the front or put the 2 sheets (roof and front) together right at the top corner?
Also nobody has suggested what thickness sheet metal or aluminum they would use to skin this trailer in. And how much heavier would the sheet metal be than the Aluminum. I really want to keep my same paint scheme that I have now. And I think sheet metal would be easier to paint than aluminum?
Thanks everyone for the help with this.
Sent from my iPhone using Tapatalk Pro
halfdome, Danny wrote:lacofdfireman wrote:Some great ideas and replies. Thank you. My concern is this edge right under my front window. Do I cut the sheet metal or aluminum at this edge or try and bend it there. I know the window will help hold the aluminum or sheet metal in place also just concerned about this angle. Not sure how to approach it. Originally it is sheeted with 2 separate pieces of plywood then the edge was filled with bondo and sanded. But not sure if I should try and bend a single piece around that edge or cut it into two pieces like was done originally.
If I were doing it I'd put the front piece on last and do a bend at that angle and adhere it with the white foam VHB tape.
It would be nice if that front corner, from the frame up to the roof + 2", ( two bends) were one continuous piece of aluminum to ward off freeway driven rain.
Years ago one of the members made a sheet bender out of 2x4's but can't remember who it was.
You'll need to clamp a 2x4" over the area continually with the tape for 36 hours to make it adhere, and shim any gaps under the 2x4.
Use denatured alcohol to clean the mating surfaces for a correct bond.
I use two strips of the 3/4" wide VHB tape.
I have no idea what lies below that corner and if it could stand up to the pressure of clamping.
If you don't clamp the overlap then use stainless steel screws about every 2' or so.
I'm sure sheet metal will be considerably heavier and harder to work with than aluminum.
I use .030 thick aluminum and have in the past used .050 on a continuous roof as it was the only thickness available in a 5' wide sheet.
On my roof I've always put 2 layers of glued together 1/8" Baltic Birch plywood from the front to the galley hinge, so your 1/4" plywood should work, good luck.
Danny
Danny
