Interior Paneling Gaps
Postby dmschellaz99 » Sat Sep 26, 2020 11:11 am
I’m working on lining my trailer interior with 1/8” Baltic birch plywood sheets. In each of the corners where sheets come together it’s difficult to get the gaps perfect and I’m looking for ideas on how to cover these gaps.
I don’t like the idea of using a quarter round wood trim as it seems kinda bulky. I’m thinking some sort of caulk but can’t find any caulk in the right color to match the birch. Any ideas?
dmschellaz99
Re: Interior Paneling Gaps
Postby tony.latham » Sat Sep 26, 2020 12:16 pm
Is this the wall/headliner joint? How big of a gap? 1/8"?
:thinking:
Postby lfhoward » Sat Sep 26, 2020 1:25 pm
I used birch plywood for the ceiling and knotty cedar for the walls. I covered the gaps with strips of pine.
lfhoward
Postby dmschellaz99 » Tue Sep 29, 2020 7:13 pm
Yeah I actually built my trailer out of 1”x1” steel tubing so I have to sheet the interior steel/foam insulation. The gaps vary and are about 1/8” to none based on how good I got with cutting the interior panel.
dmschellaz99
Postby MickinOz » Tue Sep 29, 2020 10:18 pm
Mask up with electrical tape, as narrow as possible. Caulk with either white or black Sikaflex 252, tool it in real tight, and peel the tape while the caulk is still wet. Make it a bit of a feature. Practice on scrap first.
MickinOz
Postby noseoil » Wed Sep 30, 2020 8:32 am
I made some flat molding to cover the gap where the canvas didn't quite meet the walls on the headliner. It's thin enough to take the front curve (a 30" radius in my case). The headliner was good when it went in place & formed well enough, but the 5' wide canvas was only 58" wide. This stuff would be similar to the flat molding sold in lumber yards as "screen molding" used to cover the joints in a screen door, if they still make that type now...
160267
137905
noseoil
Images: 669
Postby swoody126 » Wed Sep 30, 2020 9:07 am
one possible solution could be from the upholstry industry
WELTING
a piece of cordage(3/16" in this case would cover your 1/8" gaps) wrap'd in a vinyl or fabric that compliments the build
older cars and some more modern builds use it between bolt on components
American LaFrance used welting between the side boxes and main tank enclosure on my '64 firetruck
IMG_4339 2.jpg (89.59 KiB) Viewed 1276 times
just another option
sw
swoody126
