Tomterrific wrote:I can't conceive of a door lighter and more flimsy than mine. It is made with Revolution ply and has cheap 1x3 on the edges. just a simple screen door latch secures it. The door is too stiff for magnets to pull a warp out but could help keep from warping over time. I did use little magnets to secure a screen curtain so we could be inside with the door open.
Could you give a description of your door construction?
Tt
saywhatthat wrote:Tony on your door jamb it looks like you're using two different type of seals?
