Capebuild wrote:I purchased my aluminum (.040") from a somewhat local distributor. But if there are no suppliers where you are located, you may want to look into this company
harborsales.net
I don't remember who it was but another member on this forum mentioned them. I looked them up and they seem to have a good supply of aluminum, anodized (silver) as well as colors.
I think they had 5 x 10 sheets in white only. That size seems to be limited to white.
If I remember correctly, I think they were in the Maryland area. I'll go to their site, if I'm geographically "off" I'll report back.
good luck.
John
Thank you so much for your response John! I managed to get the 5x10' 040 aluminum sheeting from a local sign shop. Now I got a new worry about bending the aluminum sheet.
I have never worked with aluminum before. As shown below, my naive thinking was to use one sheet to cover from point 1 through 5 (approx. 101") with 3 bending points (2, 3, 4). I don't have a bending machine. Will this be a problem with the 040 aluminum sheeting?
I also intend to build a hatch that spans from point 5 to point 7. I'm not sure where to place the hinge, also point 6 is a sharp bending point, not sure whether that's a problem.
- sheet-bending.png (334.66 KiB) Viewed 428 times
