Making a pattern.
Making a pattern.
Postby Shrug53 » Thu Jul 01, 2004 4:57 pm
OK, here is something that has not occured to me before. Once I find a shape I like on paper, how do I make it in to a full size pattern?
"Better living through reckless experimentation"
http://www.forgottenclassics.com
Shrug53
Postby mikeschn » Thu Jul 01, 2004 5:18 pm
You make a beam compass out of a 1x2 and just draw it on a piece of wood!
Images: 479
Postby Shrug53 » Thu Jul 01, 2004 6:00 pm
I have no idea what you are talking about, but it must be important since you said it 3 times :)
Shrug53
Postby mikeschn » Thu Jul 01, 2004 6:53 pm
The web was misbehaving at the time!!!
Anyways, if you can draw your shape on a piece of paper with a compass, you could make a larger beam compass with a 1x2 piece of wood. Put a drwyall screw on one end, and a hole to fit a pencil on the other end, and swing your radius.
If you end up with a profile like the one I just saw you post in another thread, you'll have to map all the grid points to your piece of wood, and then use a flexible piece of wood to connect the dots.
Does that make sense?
Images: 479
Postby tdthinker » Thu Jul 01, 2004 9:34 pm
That is how Wayne taught me.
Ryan
tdthinker
Postby Grant » Thu Jul 01, 2004 10:18 pm
Try this:
Take your 8-1/2" x 11" drawing down to your friendly Office Depot, Kinkos, or full-service copy shop and have them copy your artwork on a transparency ... take the transparancy home and borrow an overhead projector ... project the image on your plywood propped against a wall, or heavy-weight craft paper tacked to the wall, and move the projector closer or further back to get the image to the full-size you desire ... trace the image onto your plywood, or your craft paper, and viola! ... you have your full-size pattern. Works like a charm, and you get an EXACT copy of your original drawing ( at least, if you trace as well as you draw ;-} ;-} ...!). Also works great for those grid-profiles you find in all those vintage trailer plans ...
CHEERS!
Grant
"Life Moves a Little Slower When You're on Teardrop Time" ... so kick back and focus on the Good Stuff!
Grant
Teardrop Manufacturer
Postby Shrug53 » Fri Jul 02, 2004 9:25 am
Being the clever young lad that I am (or as my wife would say 'the crotchety old cuss") I have figured out an alternative to my pattern problem. Kinkos will print from my photoshop or illustrator files at any size up to 3' wide (and no length limit). So I could do two 3'x10' printouts and have my pattern. The only problem is that I need 1/4" all the way around to fit the printer, but that would be easy enough to handle. All I would have to do is to tape the two sheets down to the wood and trace 1/4" bigger. The cost for this? Only 50 cents per square foot!! So 30 buks for a full size pattern on 20lb paper! How cool is that? Totally worth it if you have an odd shape like mine.
Shrug53
Postby tdthinker » Fri Jul 02, 2004 12:07 pm
I might try that, We have a kinkos 15 mins away!
Ryan
tdthinker
