Could a frame be built and then sheet metal be attached nailed, screwed, glued to the ribs then add insolation and inside wood.
Why does it need to be glued to a wood sheet .... would not that bring the weight down a whole bunch??
Ron Dickey wrote:Could a frame be built and then sheet metal be attached nailed, screwed, glued to the ribs then add insolation and inside wood.
angib wrote:Which is exactly how all commercial trailers are built, so you can do it this way.
Commercial trailers use fluted or corrugated aluminum - is that because it allows them to reduce the thickness of the aluminum, or is it because it allows them to put the frames further apart, or is it to stop the siding from 'panting' and then coming off? Were old trailers, with smooth aluminum siding, made with thicker skins?
Andrew
Welcome to the Buford and Andrew lightweight club!JunkMan wrote:If you have ever scrapped out an old travel trailer or pickup camper, you would be surprised how little material is used when building them. With the exception of a brace or two placed in corners, the only plywood on the walls is the inside paneling, and it is usually very thin.
angib wrote:Welcome to the Buford and Andrew lightweight club!JunkMan wrote:If you have ever scrapped out an old travel trailer or pickup camper, you would be surprised how little material is used when building them. With the exception of a brace or two placed in corners, the only plywood on the walls is the inside paneling, and it is usually very thin.
When it comes to old trailers, I can only talk about old British trailers, but the result seems to be the same. Minimum cost and, probably less importantly, minimum weight meant that the builders learnt what to leave out.
But when looking at old trailers, I do note:
- The framing is made of lovely quality wood - simply unobtainable in Britain today (you guys should stop complaining about wood until you've seen a British wood yard).
- The joints were well made so that the framing was self-supporting - really the ply was only needed to stop racking (twisting) as the framework was strong enough to hold up the body on its own.
Andrew
JunkMan wrote:angib wrote:Which is exactly how all commercial trailers are built, so you can do it this way.
Andrew
Andrew, I think the ribbing on the aluminum does both, it adds strength, and helps to avoid "panting" or "oilcanning". I haven't torn apart an old smooth sided trailer, but I think you are right, they did use thicker aluminum.
Considering how most of us are building our trailers, with the exception of the guys that are building for off road use, we are way overbuilding them, especially the frames. Of course, considering how small our trailers are, this is not a big problem. If we were building 20 or 30 foot campers, we would be in serious trouble
Users browsing this forum: Bing [Bot] and 6 guests
