by JLaman » Wed Oct 19, 2005 7:05 am
Thanks all for your interest in this aluminum skin flatness problem.
I took exceptional care in making certain the sides were plump and that the spars were perpendicular and true. I even waited a couple of weeks after installing the spars to make sure that they did not warp. One warped, so I removed it and replaced it with a straight spar before adding plywood. I layed a straight edge across each one and belt sanded any uneveness to get all spar surfaces horizontal with no irregularities. The 1/8 plywood did seem to have a slight buldge at the edges after I installed it, particularly the 2nd sheet. Plywood is more forgiving than aluminum (0.040), however, and it drew down without a problem. I am thinking now that maybe the 2 layers of 3/4 rigid insulation did not quite lay flat in the 1.5" spaces between the spars and caused the center sections to push up some. That would cause the edges of the aluminum to be above the plywood if the plywood was pushed up in the middle section. I am really hoping that the 1" x 1/2" molding with screws at 4" oc will pull the aluminum down enough to close the gap from water. I plan to do that tomorrow........ Otherwise, all is well and everything on the trailer is falling into place perfectly. After this aluminum disaster, I finished up the galley, looking for some success to end the day. The drawer fits nicely and cooler and water jug slide in just as planned. Thanks again.
