Vajra wrote:Thanks for the reply guys!
M C Toyer, yes to the 40" wide flat sheet. The place does metal buildings, sidings and roof systems. The have gigantic rolls of the material that are about 40 7/8" wide. Then have a system of rollers/dies they use to form the profiles they use, along with equipment for sheering, bending, etc. The can normally do average size order turn around in 24 hrs. For something as small as I am doing, less than 12 hrs for the order, but with custom work, up to 24 hrs. I think I would go flat, as the sheets could also be bent over curves, I think once a profile is added, you can only bend in one direction at that point. I was thinking much like lap joints, but not sure how else to seal it up. The roof would be the challenge at 6' to 6'6" wide. I guess I am not sure what VHB tape is, or how it is used to join the sheets. Sounds interesting. I have access to a 48" manual brake that can do up to 22 gauge. Please share anything else you know!
Vegask, correct about the gauge. The supplier told me their sheeting product runs on the thicker side, closer to 28 gauge sometimes closer to .0150". Even at .0135", you have to remember steel is stronger than aluminum. It is more dense. From what I have read, about 2.5 times (do correct me if I am wrong). If I am not mistaken, .0135 x 2.5 = .03375" Denser materials are less likely to dent. Aluminum is a much softer metal. Yes, you are right, rust can be an issue. I am sure with a 40 year warranty on the finish, their expertise on installation I can assume little rust issues. Aluminum does have issues with corrosion, I have seen a aluminum trailer fall victim to a nasty onset of it. Aluminum is also very expensive, dents easy, scratches easily, and is much harder to repair. To me, the cost alone doesn't make me think the weight savings is worth it.
Irmo Atomics, that is a very lovely vintage trailer. She looks pretty sexy for her age! Rust, nah, that is just patina finish! She might have rust, but given she is about 64 years old, I would say that it has aged pretty well. How does she pull and how is she holding up? Great picture.
Thanks all for the replies, I hope to more back, you people are great! - James
Joye wrote:It is a good idea for using steel sheets to prevent rocks and hail. The price of steel sheets is lower than aluminum. But aluminum is more durable and has stronger corrosion resistance. For steel color, you can choose all RAl colors according to your requirement.
About the seams, if you want a vertical seam, I suggest you use high-quality sealants of the waterproof, which can prevent chemical corrosion. Also, you can invite a professional engineer to help you seal the steel sliding. On the side of the frame, I also recommend you use aluminum to ensure longer service life.
Users browsing this forum: Google [Bot] and 7 guests
