mikeschn wrote:I think he means that comparing the teardrop at a horizontal position, versus the teardrop installed on your ball, that there is about an inch difference in elevation at the centerline of the ball.
Exactly, trailers always pull a little better nose high than nose down. It helps keep them from swaying. BUT way high in the nose is not good either, that will also tend to cause sway.
1-2" high is where we usually set them when we hooked them up at work.
