(The ones I ordered are white, though. Not pink--cause I'm ALL man!)[/quote]
GREAT KNOBS!!
Woody and Ira will be jealous of your port holes.
IraRat wrote:Also, since I haven't really studied the units under a microscope, there may be a way to incorporate a screen without having to remove the glass. Which means I can replace the interior glass with opaque material for privacy.
Jolly Roger wrote:IraRat wrote:Also, since I haven't really studied the units under a microscope, there may be a way to incorporate a screen without having to remove the glass. Which means I can replace the interior glass with opaque material for privacy.
I did what you are trying to do. What I did was to adhere the screen to the outside wall directly and then put the mounting ring on top of it. You could do it on the inside and it would work just as well. Since I used real brass ship portholes, I don't have double paned glass, just really think interior glass and screen on the outside. They are somewhat heavy, but so are my walls. I don't have any problems with window vibration since they are so heavy.
Paul (Jolly Roger)
My MAIN concern is the size of the window, the glass--which is pretty small. I'm kind of balancing two considerations--how much I'm actually going to be looking OUTSIDE of that window, and how the size looks in scale to the Cubby. The scale is going to be great, but I don't know about the other.
