by madjack » Tue Oct 18, 2005 12:38 am
...I went out and looked at my laquer thinner and it is the stuff for paint, I got it with the industrial black paint that I got from the auto paint place to do the frame with a year ago...no wonder it worked so well with the urethane, Thanks Doug and Chris about the different heats in the stuff...if I get it again I will get it from the auto paint store (a gal goes a loooooong way)
p.s. Rocky...read your little book that came with the sprayer and set your adjustments to their lowest...another tip if you don't know it, the trigger has two stages, the first is basically air and second is your product. if your product gets a little heavy then you can use just the air to "push" it along the surface to help avoid runs
