noseoil wrote:I figure I saved (weight) on the build, have better insulation & sound properties, and have a better design with a lower center of gravity.
Diemjoe wrote:So slightly off topic. I was doing some mockups this weekend to test my Skeleton. I pocket drilled 4 pieces of 1x4 poplar into a square to test it. Per Kregs screw length table I used 1.25 inch screws. I was able to pull them right apart although I didn't use any glue. A few questions:
Is 1x4 adequate thickness?
Is Poplar suitable for skeleton?
I'll try gluing tonight but curious if longer screws should be used?
Poplar is expensive!!!!
Thinking about ripping cheap Home Depot 2x4s framing studs to match the thickness of the foam insulation since the home Depot foam insulation isn't the same thickness as a 1x4. Any things to consider? i.e. I have heard that the pine is pretty soft and doesn't hold a pocket screw very well.
Thanks.
Don
anon1 wrote:by hand
