Sorry I did mine as per the manufacturer's instructions. For what its worth I have had no problems.MickinOz wrote:Next question:
One of the little niggles with the bolt together trailers is the way the two draw bar members are bolted to the rest of the frame.
As far as I can see, the top plate of the C channel of the draw bar is bolted to the bottom plate of the side chassis member and of one cross member.
See illustration A. It's not a lot of metal taking all the stress.
Has anyone done illustration B? i.e. use a long bolt that will reach right through all four plates, put in a couple of spacers so the steel doesn't crush (the red bits in B ) and at least bolt 4 plates together instead of two?
I hope my attempt in MS paint demonstrates what I mean.
