tony.latham wrote:I’ve used it on the 6 teardrops ...
Danny is one of those guys that when he "speaks," you should listen.
halfdome, Danny wrote:
Your welcome.
When I attach a 10’ sheet I have 2 plywood boxes the equal the height of the wall bottom of the level teardrop.
I then place equal sized strips of wood or dowels that are spaced about 16” to the tacky contact cement on the body.
Make sure they go past the top and bottom of the wall so the aluminum doesn't prematurely stick.
Then I place the sheet on the plywood boxes and tack the center of the sheet to the body.
Then start hand smoothing the sheet removing the strips as I go along.
It’s best to use a metal shear to rough cut the aluminum.
Use a high quality flush trim router bit to trim to the final profile.
Thanks Tony
Danny
Sparksalot wrote:halfdome, Danny wrote:
Your welcome.
Thanks Tony
Danny
You have the sides laid flat doing this, correct?
Scubieman wrote:Would this stuff work? i only have menards and amazon here.
https://www.menards.com/main/paint/adhe ... 486&ipos=3
Scubieman wrote:So just contact cement. Then staples to hold edges?
Sent from my Pixel 2 XL using Tapatalk
Thank you. I'll be at Menards soontony.latham wrote:Scubieman wrote:So just contact cement. Then staples to hold edges?
https://www.menards.com/main/paint/adhesives-glue-tape/glue/cement-glue/dap-reg-weldwood-reg-nonflammable-contact-cement-1-qt/25332/p-1444428681105-c-7170.htm?tid=-3181351274711529461&ipos=4
No staples. You screw the trim through the aluminum.
T
eLink wrote:Danny,
Did you do your roof in a similar way, and with the same butt-joints?
