Dare I? A fiberglass question..
Re: Dare I? A fiberglass question..
Postby Pmullen503 » Sat Apr 18, 2020 7:28 pm
I wouldn't wet the foam first. If you wet the cloth as you go it's much easier to work any wrinkles out.
As far as bridging gaps it depends on how heavy your cloth is (heavier is stiffer) and how much tension you can get on the cloth. So say you are worried most about the seams on the sides at the top. If you can wrap your cloth around that top corner a good 6" or more, you should be able to sqeegee that cloth pretty tight.
The other thing you can do is use thickened epoxy as a filler for any gaps first and then lay the cloth over it. Apply your filler and sqeegee it flat so there is no excess on the foam. Then lay your cloth right over it before it sets up. Even if you get a low spot you can fill it later because the cloth is supported by the filler underneath.
Pmullen503
Images: 67
Postby John61CT » Sat Apr 18, 2020 11:39 pm
Great Stuff or a 2-part foam kit?
John61CT
Postby RJ Howell » Sun Apr 19, 2020 5:42 am
saywhatthat wrote:Why a steel frame? Seam a waste of time and money & weight ? just use the foam with a thicker band of glass to make the frame.
Alternative filler folks can foam sanded down will glue
foam to steel
Couldn't see how I could support an overhead berth with fiberglass supports.. Now the roof should be mainly foam/fiberglass.
RJ Howell
Images: 36
Postby RJ Howell » Sun Apr 19, 2020 5:48 am
Looks like I have fall back with fairing after if filling (or bridging) first does hit my goal. Thanks guys!
RJ Howell
Images: 36
