The wetting is no big deal. But Dale, DON'T underestimate the foam-up on that GG.
You glue and clamp your pieces, it looks nice and beautiful, you turn your back on it for a second, and ...
AARRGH!!!! IT'S ALIVE!!!
madjack wrote:...had never used GG until this project came along and found for certain applications it was too handy not to use...the big advantage over say Titebond is that it does not require as much clampage to get a good bond...inna lot of instances, glue and a brad gun worked out quite well, where as with TB, this method would not have been sufficient. Howeverm GG is messier to work with and leaves a darker joint line
Artificer wrote:Ira: try not wetting the surfaces you glue. The wetting decreases the cure time, but also increases the foaming. I'll have to look it up, but I've seen on the forum that Gorilla brand glue foams more than others.
Ira wrote:I mostly used the Elmer's brand of it with the bull on the bottle (the chemical formula is like identical), and THAT stuff was nuts to work with.
I'm gonna have to buy some more of that or the GG for my fenders, and I want to be real careful about the foaming. So I won't wet it this time. Maybe I was also using too much water--I rubbed it on heavy with a paper towel.
