Ira,
I saw what you did on that text, it justs showed me my own computer, browser etc..... It wasn't really spying on you. The guys were just teasing you.
Witch wrote:If paint wouldn't work, are there any other options to adhereing canvas to wood?
angib wrote:2) Using fabric* stretched over an open framework. The fabric is then stiffened and made waterprooof by coating it. Traditionally this was done by doping it (which had the major advantage that the dope shrank the material, pulling it drum-tight) and then paiting it with enamel paint. The modern equivalent is to coat/impregnate the fabric with epoxy resin to make it stiff.
Andrew
CEO, Old Farts 'R' Us
Steve_Cox wrote:Do you know what it is about "dope" that causes the shrinkage? Maybe I should have preshrunk the canvas, and also I was using a laminating epoxy and it could have used some thinning before brushing it on.
Jiminsav wrote:Denny, it won't be soft..there is wood under it.
