asianflava wrote:Another question, do you clean the gun after every coat? or do you just leave it in the gun till you are done with that portion of the project?
I've done both. If it is fast drying between coats, I usually leave it in the gun. What you can do if you are using a bottom mounted cup, is unscrew it and put the siphon tube in some thinner or mineral spirits and spray some through the tip to clear it, then screw the cup back on. That would keep the tip from getting clogged. The cup on my guns also screw onto the gun, and has a thread that fits a standard quart jar. I can take the cup off and screw on a jar with thinner in it for clearing the tip (using siphon feed NOT PRESSURE with the glass jar on the gun). Then, I can put the paint cup back on for the next coat.
I haven't yet used my top feed gun I bought, so I'm not sure you can clear the tip with that type unless you empty the cup and put thinner in it.
When I clean my bottom cup guns when I am done painting, I clean out the cup with thinner (or water if it is water based paint), then put the thinner (or water) in the cup, replace it on the gun, and spray into a large cardboard box to clean out the gun some before disassembling it for final cleaning.
