Exterior Trim Pics - Added Rain Diverter
Re: Exterior Trim Pics - Added Rain Diverter
Postby sdtripper2 » Tue Feb 21, 2012 12:26 am
nrody wrote:I really do not know how to post photos or I would post one.
Use the Img button at the top of your edit window and highlight your URL location
as below and click that Img button to show your picture:
**** The images below are for the old forum BUT your key is using the "Img" command
on the top of your edit box here on this new forum:
(Post Box)
4)Paste The URL in your message
(Post Box)
5) Highlight The URL and hit the Img button. That's it, you're done!
If all else fails go here and find all you can stand on image showing on the forum.
Or at least this link will get you in the ball park.
sdtripper2
Search Garoux
Images: 168
Postby nrody » Tue Feb 21, 2012 12:32 am
Ok let me try. I have to go take a photo be right back
nrody
Nancy
nrody
Postby sdtripper2 » Tue Feb 21, 2012 12:41 am
Nancy :
Your Private Message asked of re-sizing pic
I replied however if you get back here first click here > http://tinypic.com/index.php for right now
to re-size to (Message Board 640x480)
When you click on uPload you will have to put in a codeded key word given to you and then copy and paste the Img code in the box under (IMG Code for Forums & Message Boards)
***** That is copy and paste in the forum here the Img code in the second box down from the top of the results screen.
In the future:
You may have a better way to re-size in the future but the one above is simple and easy to use without much learning time.
Till then Keep the URL http://tinypic.com/index.php handy for future use:
and read some of the suggestions here if you want more ideas on how to manipulate pictures.
sdtripper2
Search Garoux
Images: 168
Postby sdtripper2 » Tue Feb 21, 2012 1:14 am
Your image will have a "jpg" at the end not the mix of numbers you have on the links you used.
You must choose the box = (IMG Code for Forums & Message Boards)
sdtripper2
Search Garoux
Images: 168
Postby sdtripper2 » Tue Feb 21, 2012 1:17 am
Nancy
Try once more:
read my post above and your size should be 640x480 and choose the right box to cut and paste at the end of the short process.
sdtripper2
Search Garoux
Images: 168
Postby nrody » Tue Feb 21, 2012 1:21 am
Holey cow how did I do that?
Galley hatch springs
Hatch partially open - see the gap- pours water into the galley when open and raining
Hatch closed- the black area is the angle iron frame. The aluminum is cut away so the hatch opens
nrody
Nancy
nrody
Postby sdtripper2 » Tue Feb 21, 2012 1:39 am
well it is now alright Nancy
sdtripper2
Search Garoux
Images: 168
