Gee its 0308 and were struttin the gas
Can't put any time constraints on that!!!
Classic Finn wrote:Tony here is the top bracket we have and the way it was installed.
And Lower Bracket
Sonetpro wrote:I think your problem might be the strength of the struts. I converted Newtons and 170N = 38.217520327 pound-force.
If those are 38 lb struts they won't be enough. Your hatch looks to be about the same size as mine and I have 2 90 lb struts on it.
Sonetpro wrote:Classic Finn wrote:Tony here is the top bracket we have and the way it was installed.
And Lower Bracket
I have mine installed the same way.
As Kerry said put the big end up. That way the oil stays on the seal and it won't dry up and crack.
Classic Finn wrote:Ok the company called me back and they said that they have about the same length but 440 newtons = 98.915935 pounds force. In stock.
Close to what Sonetpro mentioned as far as weight .
or 98.915935 pounds = 44.8675134 kilograms. They said that this time it should be sufficient.
So Im going to go pick them up. Back Later but after install.
Classic Finn wrote:Ok just got home.. New shocks on hand.
This time with 450 Newtons..or 450 newtons = 101.164024 pounds force.
Now to reread the info here from Tony so I dont make mistakes.
I just wish I would of known about this Newton equation thing or been familiar with it.. I am now...
Ohh well live n learn. Now to go install.. I,ll let you know how it went.
Sonetpro what do you think about the size now?
Classic Finn
