MatTech wrote:OP, Seems to me like you are going in circles a bit with all your options. Let's get back to basics.
You have a wood sided trailer coated with raptor liner... the adhesion of the coating the wood is performing properly. What is failing you is that the raptor liner is not flexing with the trailer at your wood seams. This is letting water in and causing swelling of the wood and making things even worse.
Reading the technical data sheet of the raptor liner they make no claims whatsoever as to elasticity or flexibility. They also state that it is a polyurethane based product. If your wood is still in good health there is no reason to remove it if you plan on putting wood back on there. You just need something that will either cover the whole exterior as one continuous membrane and which will bond adequately to your polyurethane based raptor liner. Or you need cover with aluminum using well thought out sheet placement with overlap, or as others have suggested an adequate sealant at corner/seam moulding.
As for thickness the .020" thick aluminum I toyed around with was unacceptable in my case because I will be skinning directly over foam and without solid wood underneath the aluminum it dents very easily to the point of puncture. I would bet that applying that same thin aluminum to solid wood backing would be totally acceptable.
Before ripping any wood off I still recommend you wait until I've had the chance to test the samples being sent to me from Liquid rubber. They are both polyurethane based liquid membranes and should bond to your raptor liner though I will forward that question to Trevor on your behalf. The one sample they are sending is their deck coating and it is rated for 200% elasticity before failure and the other is a new formulation so they don't have a TDS out for it yet.
You've got a good looking trailer with a small flaw causing big problems. If I were you I would be looking to the liquid waterproofing membrane option as you're pretty much at the stage of being ready to apply. Everything else will be a far more in depth project.
Sent from my SM-G930W8 using Tapatalk
greygoos wrote:I am going to give my cracks and or peeled section a good cleaning and seal the area, then reapply the bed liner or black paint. Will try to get to it this week and post the result. I would try to repair your situation first before ripping it apart and starting over.
MatTech wrote:I should get a response from Trevor at liquid rubber tomorrow as to how their product would bond directly to the raptor liner. My guess is you would just have to clean the surface thoroughly and apply right on top.
So what about using this Fiberglass Resin...
