Cutting aluminum sheeting
Postby exminnesotaboy » Tue Oct 19, 2004 1:07 pm
Can someone help me with options for cutting the .032" aluminum sheeting?
- can I use my Makita jigsaw with a metal cutting blade? will I burn it out or go through too many blades to make it worth while?
- how about electric shears? probably the el-cheapos at Harbor Freight(40$) as I will not ever use them again after this project
- clearly, the best option would be air shears. I know they are easy to use, but I just can't justify the cost of buying an air compressor to run it, and never needing it again - plus no place to store it after the project is complete.
I have friends that will lend me a compressor for the weekends, but they are all the pancake/nailer compressors and I don't believe they will keep up the volume needed for the shears - but they will work great for a brad nailer :D
In January/February, I will be building a Kuffel Creek Cubby. For the next couple of months, I am learning as much as I can, collecting tools, obtaining materials, etc.... this board has been invaluble to me - Thank You!
exminnesotaboy
Postby mikeschn » Tue Oct 19, 2004 1:10 pm
Using a jigsaw worked out pretty good for my on my first teardrop!
Images: 479
Re: Cutting aluminum sheeting
Postby DanD » Tue Oct 19, 2004 2:53 pm
exminnesotaboy wrote:Can someone help me with options for cutting the .032" aluminum sheeting?
I have a pancake compressor in my shop and if you use it in short bursts, you can run air tools. I mounted my axle, tires and wheels with an air gun running off the little compressor just the other day.
I, too, am building a Kuffel Creek Cubby
DanD
Postby Clancy Courtney » Tue Oct 19, 2004 4:05 pm
I cut the profile out with the Al panels sandwiched between the 3/8" plywood with a jigsaw. It cut very well. I also used the HF air shear with my pancake compressor. It couldn't keep up. I bought a HF electric shear and it cut .032" easily. The electric shears krinkled the edge but maybe I didn't use the correct technique. I also cut some on the tablesaw again sandwiching the Al between scrap 1/8" plywood and had good results with carbide tipped blade.
Good luck,
Clancy
Clancy Courtney
Images: 11
Postby DanD » Tue Oct 19, 2004 4:42 pm
Clancy Courtney wrote:. I also used the HF air shear with my pancake compressor. It couldn't keep up.
Other than the compressor not keeping up, how well did the HF air shear cut?
I think they just put it on sale.....
DanD
Postby DanD » Tue Oct 19, 2004 4:44 pm
DanD
Postby Stephen G. » Tue Oct 19, 2004 9:25 pm
Hello,
Can you use a router to cut and trim aluminum sheet?
Stephen
Stephen G.
Postby exminnesotaboy » Tue Oct 19, 2004 10:08 pm
excellent - it looks like I can use my jigsaw and pick up an electric shear if need be
thank you to everyone for the quick feedback!
Anthony
exminnesotaboy
Postby Denny Unfried » Wed Oct 20, 2004 8:35 am
Stephen G. wrote:Hello,
Stephen
I used a router with ΒΌ" straight carbide cutter for all my aluminum cuts. With a variac I lowered the voltage to 40V to slow the cutter and prevent melting the metal. Of course you have to use a router collar to follow the profile and this leaves a very clean cut. Also there are a few pics on my web site.
Denny
Last edited by Denny Unfried on Wed Oct 20, 2004 11:29 am, edited 1 time in total.
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby Clancy Courtney » Wed Oct 20, 2004 8:43 am
DanD, The air shear cut very well. It was just a slower process waiting for the compressor to build back up.
Clancy
Clancy Courtney
Images: 11
