Camp Inn & Hunter Shadow side wall const. ?
Postby Dave M » Thu Oct 21, 2004 10:58 am
:?: Hi all, I am developing plans to build my own 5'x8' tear and am mulling over the sidewall construction. I am leaning towards insulated skinned construction (1/4" ply outside, 1/2" insulation between 1/2" studs, 1/4" ply inside) but I have noticed that both Hunter Shadow and Camp Inn seem to use ply only for the side walls.
Anybody here familiar with their exact sidewall construction? What thikness are they, is it one peice ply or is it skinned inside with a higher quality ply? How well do they handle cold temps? I live in CA and would do mostly 3 season camping but would like to be able to take the tear to the snow once and a while.
Thanks,
Dave
Dave M
Postby campadk » Thu Oct 21, 2004 3:13 pm
Hi Dave,
The Hunter is 1/2" plywood.
We camp from early May through till end of October here in the north, so it gets a bit nippy, especially at either ends of the season. We have a 7W ceramic heater/fan combo which tops up on body heat on very cold nights. Having insulation in the ceiling is what is most important. With thinner sides and no side insulation we do get some condensation however. It isn't a big issue though. If you are insulating the side, I'm sure you'll keep plenty toastie! Just don't forget to bring the wife! :shock:
campadk
Teardrop fun specialist
Images: 34
Postby Betsey » Thu Oct 21, 2004 11:01 pm
Camp-Inn uses a 3/4" solid plywood sidewall. We have camped in ours down to about 15 degrees F. Even in the cold weather, we open the side windows slightly to vent the warm humid air to minimize the condensation. We still get some condensation on the windows and slight condensation on the sidewalls. The most important thing is that your roof is insulated, so the condensation doesn't rain on you. The Camp-Inns have foam insulation in the roofs.
Of course everybody's idea of "a little brisk" is different. Having lived in northern Minnesota, in February when it warms UP to 5 below, everybody comments that it feels good now that it isn't very cold anymore.
We don't have a heater in our teardrop, just a couple extra blankets and we have always been comfortably warm. Of course, depending on how cold it is, it helps to wear flannel nighties and a nightcap like in "The Night Before Christmas" so you aren't as tempted to stick your head under the covers. At night it takes a few minutes to warm the sheets. In the morning, close the windows for 10-15 minutes and it warms up so you can't see your breath anymore. A small DC heater would help speed this process.
Camp-Inn does offer a propane furnace for the cold blooded. :D
We are going to try some winter camping, in the snow, this winter.
Anybody up for a sub-zero teardrop gathering? We could ice fish, ski, sit around a BIG campfire....
Betsey
Betsey
Images: 35
