mikeschn wrote:Hey Steve,
That's an interesting way to clamp those babies down. Hot glue! But I think I would need more than 1 slice of blueberry bread. That project must be time consuming, to say the least. 2 evenings out there any you're only 2/3 of the way done. You've got the patience. Not me.
But it's going to be sweet looking when it's done if that picture of the kayack was any clue!!!
Michael Rodriguez wrote:There is an easy trick to doing the inside curve I learned from someone who builds Teardrops for a living. It is probably too late to do this since your ribs have already been attached, so this will be for prosperity. I used 1/8" mahagony plywood for my inside curve. I finished the interior exposed side with a tung oil finish so that it would be prefinished and still bendable. I glued the ribs to the plywood first. Then after the glue cured I attached each rib one by one up the side bending as I went along.
