Engineered Hardwood Flooring
Re: Engineered Hardwood Flooring
Postby airdonut41 » Wed Nov 04, 2020 5:10 pm
Awesome! So no issues with expansion, I take it? I'll have to come up with a way to hide the staples, but that seems pretty tractable (particularly because I can use gravity/weights as a clamp for glue!).
airdonut41
Images: 28
Postby aggie79 » Thu Nov 05, 2020 9:50 am
Some mentioned there would be expansion issues; however, I did not have any issues.
The engineered flooring I used was cross-laminations of wood with a top hardwood lamination. Essentially, this engineered flooring is plywood. Therefore, it had the same expansion rates, due to changes in moisture content and/or temperature, as the plywood framing it was attached too.
There are some flooring products that laminate a hardwood layer to fiberboard substrate. Others, like the original Pergo floors, laminate a vinyl or plastic laminate to a fiberboard or dense paper substrate. Because they probably have different expansion rates than plywood, I don't think these products would work.
Postby tony.latham » Thu Nov 05, 2020 8:34 pm
We used it in our house. It doesn't move. That's the beauty of it.
Postby noseoil » Sat Nov 14, 2020 8:57 am
There are different types. The ply-core stuff is good, particle core not as good. In Tucson we would leave a 1/2" gap at the walls for expansion from dry season to July-August when humidity was increased quite a bit. In a small trailer, it's not a big deal, but a small gap at the walls would still be a good idea, perhaps 1/8" would be sufficient unless the rain gets in and soaks an area of the floor.
137905
noseoil
Images: 669
Postby bdosborn » Sat Nov 14, 2020 10:14 am
I used super cheap, closeout stuff that was in a pile by the door at Home Depot on mine. "Hmm,, that's pretty cheap,think I'll grab a couple of boxes." Then I butted it up pretty close to the walls with a minimal gap, figuring I would have to redo it sometime down the road. 10 years later and no complaints.
Images: 772
Postby tubularfab » Thu May 06, 2021 11:47 am
I think the Engineering hardwood is a good idea - and am giving it a try. Here is my build thread just to link the topics together: viewtopic.php?f=50&t=72891
tubularfab
Postby wysedav » Thu May 06, 2021 2:12 pm
I did that in my teardrop. Looks great no issues at all other than weight. I'm sure I've posted pictures on this site.
David
wysedav
Users browsing this forum: No registered users and 24 guests
