by DANL » Tue Mar 22, 2005 8:59 am
Got your message, Mike...
The paint is holding up fine. The POD has been sitting outside, uncovered, all through the winter. A bit of leaf dirt and the usual airborne garbage but otherwise it is doing great.
Since I will be making modifications this summer, just touching up with some more paint is an easy way to go. I've contemplated the whole skinning and finishing topic and have come to these personal conclusions.
1. If you want to keep expenses down and you aren't concerned that your trailer must last 20 -30 years... Paint is fine. Just keep in mind that you will have to do touch-ups now and then. I have quality latex paint on the outside of the house and we only repaint every 10-12 years.
2. If you have created your personal masterpiece and you want it to survive for a long time or you just don't want to have to do maintenance other than washing... go with Uniflex 255 or the fiberglass product of your choice or aluminum.
From what I have read here on the forum, I get the impression some folks can bang out teardrops in their sleep while others will take a lot longer. Some are going mainly for a functional unit while others are creating masterpieces of the woodworking art. Some folks are skilled with tools and equipment while others are learning as they go. Some might even toss the first one after a few years or uses and build their "ultimate" TD or TTT based upon what they learned from the first one.
Anyway, Just go with what seems appropriate but think about this... choose the solution you can live with.
Would I paint again? I have great confidence in paint and will continue to use it for the next "experiment" BUT when I do get around to building my "ultimate" trailer, it will probably be covered in aluminum or glass fiber panel.
