angib wrote:JunkMan wrote:I didn't think that you could use a deep cycle battery in a car for any length of time, that it was designed to be slowly discharged and recharged, not rapidly, like a car would do.
Nope, there's no problem in using a deep cycle battery this way - the only problem is that they won't be able to deliver the same CCA (cold cranking amps) as a similar sized car battery, particularly in winter.
And remember that plenty of boats' batteries actually are used just like a car battery - they start the boat's engine and the engine is running much of the time the boat is in use.
Andrew
Yep--and here's another issue to keep in mind:
Boat supply places (and some automotive) sell an inexpensive solar trickle charger. It's just a small photovoltaic panel with two leads that you clip to the battery terminals. Of course, depending on where you live will affect its suitability, but don't underestimate this even in cold climates. If there's sun, it works.
A deep cycle is going to hold a charge and provide a lot of juice for a long time --depending on how many amps you're pulling from it. An electric drill is going to pull a lot, but your Cubby lights, electric sink, even a small TV are hardly going to pull any amps.
In your car, you're actually charging you're battery as you drive. For people with boats, who MAYBE get out for a few hours now and then, it's not getting the charge, so then these batteries need an inexpensive battery charger. And deep-cycle batteries are able to be more or less fully discharged many, many times, and rechargea, to come back to life.
I would still use a separate battery for the Cubby.
