HI,
After few month of reading it's now time to start the building of my teardrop.
I could not find good trailer that fit my need so i decided to build it. I will bolt it first and get it solderend later. But i don't know the minimal spec for the steell i should use to be safe and light weight (for now i only have a small car). my plan was usign a 2" X 2" X .100" steel square tubing to make a small 4' x 4' frame holding the suspention and the tong on it. And then make a 4' X 8' frame using 2"x2"x .100" corner bolted on top of the first one. The frame will be light around 120 lbs with out the suspention axle etc...
I'm on the right way?
Michel
