Progress made: Door trim DONE!! Hinge on Inside or outside??
Postby Geron » Thu Apr 14, 2005 6:27 pm
Made some more progress. Door trim done
[url="http://www.hunt101.com/?p=275260&c=500&z=1"]Image[/url]
[url="http://www.hunt101.com/?p=275258&c=500&z=1"]Image[/url]
I think I'll mount the hinge on the inside and put the angle trim and hinge up with the same screws.
Geron
Geron
Images: 173
Postby TonyCooper » Thu Apr 14, 2005 8:55 pm
Your progress and work is impressive. I'm planning to go with the hinge on the inside. I think it looks cleaner. Again nice work!
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Postby Steve Frederick » Thu Apr 14, 2005 9:10 pm
Wow! That's really nice metal-work! Neat, Smooth! Nice job!!
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Geron » Fri Apr 15, 2005 5:02 am
Thanks guys. I went through a "why'd I start this thing" but now I'm having fun and gettin' it done. Actually looking forward to the doors and hatch. Just hope the top skin goes as well as the sides. I'm using .040 instead of .032. all around but I'm not worried about weight.
Geron
Images: 173
Postby purplepickup » Fri Apr 15, 2005 7:52 am
I'll echo Steve's comment about the very clean looking metal work. Nice!
As far as the "why'd I start this thing" feeling...I've noticed that once we have committed publicly (on this forum) to building a trailer we can't just throw in the towel. It's that human trait of not wanting to be a loser. ;)
George
purplepickup
Postby norm perkiss » Fri Apr 15, 2005 9:18 am
Geron,
Excellent metal work, do you have and tips on persuading the angle? Did you anneal the aluminum?
Norm
norm perkiss
Images: 62
Postby Georgeandpat » Fri Apr 15, 2005 11:21 am
Hinge inside definitely! As far as the trim under the hinge I just installed them with caulking and, as you mentioned, used the same screws to secure both hinge and angle trim.
Georgeandpat
Postby Geron » Fri Apr 15, 2005 1:42 pm
norm perkiss wrote:Geron,
Norm
I cheated. I ordered the T1 from Grant. It bent like butter. I did experiment with the T5 angle from HD. 1/2 x 1/16 with one side cut to around 1/4 to 3/8 inch it would bend quite easily when annealed. HD also has the 1/2 x .050 angle. I used this for the straight side because the trim I Got from Grant looked like .050 like the hatch hinge. Annealing of the HD angle was not a problem but time consuming. I feel certain I'll use HD aluminum one my NEXT :? one.
Geron
Images: 173
