FRP paint
FRP paint
Postby scruffy » Sun Apr 17, 2005 5:06 pm
wondering if you can use fiberglass tape and resin on the corners of frp
covered tear and can you paint it with auto paint?
scruffy
Postby doug hodder » Sun Apr 17, 2005 6:30 pm
Glass tape and resin can be painted with automotive paint. As far as the bonding properties with FRP, I don't know, haven't worked with it, you might want to check it out with the technical staff at west systems. www.westsystems.com They got right back to me with questions that I had. Doug Hodder
Postby roger-c » Sun Apr 17, 2005 6:51 pm
Scruffy
A lot or truck dry boxes have FRP sides and at our truck shop we have been repairing and painting then for years with no problems. If you use FRP panels I would do your glassing using SMC compatible resin incase the material is made with SMC resin. If you use regular resin it will separate over short time.
rogerc
Don�t force it use a bigger hammer!
roger-c
Images: 9
