A question for the tongue meisters
Posted: Tue Apr 19, 2005 8:27 pm
I'd like an opinion from someone that has had some experience building trailer frames.
I'm putting a tongue on my frame and thought I'd ask about the design before I weld it on. In the picture below you can see the coupler that I clamped some 2X4's into so that I could mock up how the tongue would fit. It will actually be welded under the frame but for mockup purposes I left it on top. I'm cutting the straight tongue off that's on there now. The material I'm using is 2 X 3X 3/16 angle and my thought is to make a v-cut in the top at the red marks (which are at the front frame rail) and bend the angle, at that point, straight back and weld it to the second crossmember or bend it less and weld it to the side rails. I'm leaning towards the second option because the side rails are stronger than the cross member and the contact area (and welds) would be longer. It will be welded to the front of the frame too. The blue marks indicate where I'm planning on cutting the angle (73"). I just didn't want to cut the 2X4's.
The front of my trailer will curve out 12" forward of the front frame rail so the ball of the coupler would be 55" from the frame and 43" from the most forward point of the front of the trailer. I feel this is enough since my 6X12 utility trailer is 40" to the coupler and my 24' car hauler is 45" and I've never had any problems with them.
Sorry for the long winded post. Any opinions?
