3/4" Plywood only sides
Postby Gerdo » Mon Apr 25, 2005 12:06 am
What are the pros and cons of 3/4" plywood only sides compaired to insulated side walls?
Gerdo
Images: 156
Postby darkroomsource » Mon Apr 25, 2005 1:19 am
Easy and fast.
I have no insulation in my teardrop and have not had a cold or hot night.
But we haven't been camping in the snow either.
-- Andy Hughes
My Teardrop
Grace Happens
darkroomsource
Postby len19070 » Mon Apr 25, 2005 5:14 am
I build a 3/4" side that covers the frame. You can have the best of both, 3/4" wall and insulation. Just make the inside wall finish a "Foam backed Rug". Granted its not as good as foam insulation but it is something, and you have to finish the walls anyway. I live in Pa. and camp from April to mid November and the cold has never been an issue. In the summer I have a 12volt fan (pictured) and a full door screen. If you do this put the rug on before you put the roof on, it makes things a lot easier. The photos below are of a foam backed Vinyl (same theory).
http://pg.photos.yahoo.com/ph/len19070/ ... pg&.src=ph
And Yes.. it is easy and fast.
Happy Trails
Len
len19070
Images: 24
Postby Gerdo » Mon Apr 25, 2005 10:57 pm
I want it strong, easy and warm/cool.
Gerdo
Images: 156
Postby SteveH » Mon Apr 25, 2005 11:06 pm
I used 3/4" plywood only for the sides. The original teardrops used 1/2" only for the side walls and floors.
SteveH
SteveH
Images: 42
Postby doug hodder » Mon Apr 25, 2005 11:38 pm
I used 1/2 inch ply as the core, mohogany on the exterior, I'm building a woody, and birch ply on the interior. total thickness 1". Something to think about is that plywood on the interior won't take stain on as evenly as other materials. I guess it's all what you want the look to be. Doug Hodder
Postby Denny Unfried » Tue Apr 26, 2005 9:21 am
Even today some of the commercial builders are using 1/2" walls and floors which can save on the weight and expense. Using 3/4" not only makes for a very strong box but the 3/4" side doors are very solid and tend not to warp.
Another couple of cents worth from Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby shil » Tue Apr 26, 2005 10:18 am
I used solid 3/4 ply for my sidewalls, no regrets.
The piece removed from the door opening I used as the door, the window openings are the awnings. No warpage, but it's not yet been a year.
The trailer has survived it's first winter with no problems, no leaks, and no fungus.
Good Luck, whatever you decide.
shil
Postby Georgeandpat » Tue Apr 26, 2005 5:09 pm
I can't speak about the 3/4". I insulated my tear as per the Cubby plans and am very pleased with the results. It was a lot of work but I really like the thicker look and feel of the sides and doors. I would think that insulation would also cut down the outside noise as well. A framed out wall also provides a void to pull wire and install backing for coathooks and other things with screws. George.
Georgeandpat
Postby ALAN GEDDES » Tue Apr 26, 2005 8:28 pm
1/2 w/o insulation and we've been down in the low 30's and had to crack windows.
Alan
ALAN GEDDES
Images: 34
Postby DestinDave » Wed Apr 27, 2005 3:05 am
Doug.. did you use a full sheet of 1/2 for a solid core or cut out a lot of it leaving support framing? I'm considering 1/2 ply but cutting out all non-supportive pieces leaving a frame around the edges, door opening, and cabinet mounting areas. A lot of waste I know but quicker than cutting all the 1x2 pieces and joining them together to make a frame. Dave Speicher
Reality? What a concept!
Building "The Salty Tear" - a photo log of the project.
http://www.bluezenphoto.com/p979644357
DestinDave
Postby doug hodder » Thu Apr 28, 2005 9:16 pm
Dave, I used a solid sheet of 1/2" material. To get it to the 10 feet, I used a 3 wing cutter and cut the pieces on the aft end and glued them up using epoxy and a maple spline. They are way stout. My trailer is pretty heavy however, not to be pulled with a Yugo. I did it this way as I sort of wanted to fast track it to make the Ne. gathering, so didn't think out any short cuts. All of my wiring is done through the ceiling, no side walls. Trailer running lights/brake etc... will be done underneath. Number 2 will be done differently... It's a learning process. Good luck with your build. Doug Hodder 8)
Postby DestinDave » Thu Apr 28, 2005 9:33 pm
I'm running all my wiring through the ceiling also that's why I thought a 1/2" core for the walls would be plenty. Thanks..... Dave
DestinDave
DITTO on 3/4" Ply
Postby darockrider » Sat May 07, 2005 1:13 am
I also opted for 3/4" plywood sides on my current teardrop project. Ease of construction was main factor. I plan 2" insulation in floor and ceiling! My last teardrop had no insulation and very thin autostore carpet on 1/2" walls. I was never cold although didn't have really cold weather when camping maybe high thirthies was coldest! Amazing how quick body heat will build up in a small interior volume. Humidity is sometimes a problem but a small DC computor fan helps immensely!
Gerald in Winnipeg :x
darockrider
Images: 25
