Got the frame done (almost)
Postby asianflava » Tue Apr 26, 2005 11:41 pm
I got my steel and dropped it off at my buddy’s shop yesterday.
http://www.jkcustoms.com
Today, I went over there around 7:30 to start working on it. I cut the miters and cut everything else to length, then I set it up and had my neighbor weld it up. Two and a half hours later, my frame was done (except for paint, chains, and lighting). I towed it home without lights, tag, or chains; it is only 3 miles. The roofing compound is still not dry (I guess I put on too thick). I’ll find out if it fits this weekend.
Started with this:
<IMG SRC="http://www.teardrops.us/userfiles/asianflava/P4260044.JPG">
2 and a half hours later:
<IMG SRC="http://www.teardrops.us/userfiles/asianflava/P4260050.JPG">
asianflava
Postby Guest » Tue Apr 26, 2005 11:49 pm
Rocky,
Want a good laugh?
Check out my frame profile...
http://www.teardrops.us/userfiles/Dean/Copperwood%20Teardrop/FrameProfile.png
See what that sandwich floor did for you?
BTW- Your frame looks nice and light!!! :thumbsup:
Guest
Postby asianflava » Wed Apr 27, 2005 12:51 am
Holy cow! That is a bit of overkill don't you think? I guess it's better not to find out. I am still undecided as to wether or not I will install a tongue box. I would like to, but it might be too much of a pain.
asianflava
Postby Guest » Wed Apr 27, 2005 1:02 am
I'm sure you will have the weight allowance to play with, but you might want to consider going with a tounge stiffener. Oops... There I go again...
Uh...You should have seen my frame before I lightened it... :lol:
Guest
Postby SteveH » Wed Apr 27, 2005 7:01 am
Frame looks good, Rocky. :thumbsup:
SteveH
SteveH
Images: 42
