Rocosil wrote:I've come across several remarks about the use of roofing tar as a protective coating for TD floors and trailer frames and its being less than pleasant to work with, mostly because it takes such a long time to dry. Has anyone tried using coaltar epoxy (Sold by, among others, Z-Spar as "Poxitar") instead? It's also messy to apply, but it does set up a lot faster than roofing tar and, while it gives a harder finish, it still has a enough flexibility left in it to resist chipping. I'm asking because I have used it on steel boats over Pettit's Rustlok and for undercoating on cars, and I still have a gallon of the stuff left that I could save for if and when I ever get to build a Teardrop.
