arnereil wrote:well, first, the seam has to be on a joist/stud. second, it has to be well attached. Third, the end grain is the big weakness. The end grain is what will fail first, 95% of the time.
So, seal the end grain before putting the ply on. Be sure it is well attached to the joist ( I would recommend no more than 3 inches between screws). Don't spare the adhesive.... lots of adhesive. You don't want the seam to be able to flex at all..... autobody filler works very well...
I might also consider fiberglass tape over the seam, probably 3 inches wide.
Some migh use a baten instead, but if the seam is sealed and rock solid, I think glass tape is enough.....
Then a good coating, and I don't think latex is a good coating for a tear, but that is just my opinion......
Users browsing this forum: Bing [Bot] and 7 guests
