Also, what kind of wood are you using for your spars?
McTeardrops wrote:Ira
My stringers are generic Home Depot pine. Found a straight 2 x 12 with nice grain and some heft to it, ripped to 1 1/2". Hinge spar is laminated oak, 3" x 1 1/2". Attached with #8 x 1 1/2" square drive pocket hole screws from McFeely's, and PL glue.
Chris C wrote:IraRat, you'll need some sort of substrate onto which to glue the aluminum
IraRat wrote:Chris C wrote:IraRat, you'll need some sort of substrate onto which to glue the aluminum
So do I get labeled a Kuffel basher again when I say that the Cubby plans call for .032 and no substrate?
