by madjack » Mon Jun 06, 2005 7:51 am
...I have been in the construction biz off and on most of my life and I hate using that stuff in an inside setting because it will get brittle with age, protecting it from UV's will give you some use out of it but I would consider it temp at best...do you really want to trust your investment in labor/money/love that you have in your TD to something that WILL eventually fail???? Annealing aluminum is not that difficult and a good rubber mallet and a block of wood will take care of most of your problems with the aluminum trim.
However it is up to you...YMMV
