Aluminum Skin Clean Up
Postby Steve E » Thu Jun 09, 2005 10:07 am
Our teardrop is under construction and we just put aluminum skins on it. Would appreciate any ideas as to what to use on the aluminum to get smudges, glue etc. off? Not ready to polish yet but just want to clean it up. Any imput is appreciated....Thanks Steve E
Steve E
Postby Chris C » Thu Jun 09, 2005 10:09 am
You didn't mention what type glue. Your best bet is to use the solvent suggested for the glue. Whatever it is, it won't phase the aluminum.
Chris :D
Chris C
Postby Steve E » Thu Jun 09, 2005 10:26 am
When want to clean aluminum just in general from any finger prints etc. what product do you suggest...Have never dealt with aluminum and it seems to be unforgiveing as seems to show everything...Thanks
Steve E
Postby Chris C » Thu Jun 09, 2005 10:46 am
If you're talking fingerprints, just try soap and water.
Chris :D
Chris C
Postby San Diegan » Thu Jun 09, 2005 11:10 am
You might want to look over here http://www.tnttt.com/viewtopic.php?t=3731
Thanks,
San Diegan
Postby fornesto » Thu Jun 09, 2005 2:21 pm
As I finish up, I am experimenting with different exterior treatments. I polished one side and, well, it needs more buffing. It took the matte look away, but now I feel like I've made a big committment. For new aluminum with mill finish, I used a can of Stainless Steel Polish (which also works great on aluminum) It sprays on, hazes and is wiped off. Does the trick and quick and easy. The can's not so cheap. To remove glue and other gunk, lacquer (liquor) thinner works well. A little on a rag and it takes everything, including silicone, right off the aluminum.
fornesto
